rupert-colley avatar image
rupert-colley asked
ESS Settings
We have a Multiplus 5k 48V,Blue Nova 8 kW Battery 150 Victron mppt charger and a coloraturas contollerThe Multiplus has the ess app installed I am unable to get the ESS to let my battery run below 65%I would like to run the battery down to 75-80%How do I set this?
ESS
max-1 avatar image
max-1 answered ·
That could be due to the ESS Mode you selected. As far as I can remember, setting the mode to Optimized (with BatteryLife) does that. If the setting is on Optimized (without BatteryLife) you can manually set the min. SoC.
