Hi, can EasySolar II be set up like this?
- no ESS, no country code entered
- power to loads is supplied only from DC battery
- AC IN is enabled only when the voltage of a battery is low so charger can bring the battery up to desired level without disrupting power delivery
I'm almost sure this can be done - as described in Virtual Switch Ignore AC lesson found elsewhere.
Can anybody confirm this is a valid setup?
Thank you
Petr
