Is it safe to use two inputs ( Grid and generator ) connected to an automatic transfer switch in this manner as shown in the image below ?
Does the easysolar II gx accept voltage that might not be stable coming from the generator ?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Yes, there should be no problem using an ATS on the AC input like this. The Inverter setup includes a check box for weak ac input, and some other parameters may need adjustment depending on your generator.
29 People are following this question.
