carlos-colasanti avatar image
carlos-colasanti asked
Multiplus II simple configuration
Good Morning,
I have just bought a Multiplus II 48/3000/35, Venus Gx, solar panels, controller Mppt of another brand, and economic batteries of 180 ah capacity.
It is my first time that I configure such a system; I have read a lot on the Victron website and seen several tutorials on YouTube from Victron, and try to configure the Multiplus with the Self consume Hub 2 function of the Assistant.
I would like to ask a simple question:
Can I simply configure the Multiplus II to work as an inverter while the battery has a voltage higher than 48 Vdc, when going down from this value it passes to deliver AC voltage from the grid, and when returning the battery to a voltage of 51 Vcc, it works again as an invverter?
How I can do that? At the moment I do not want to use the grid for any other function !! Thanks in advance for your help !!!
Best regards,
Carlos from Argentina
boekel avatar image
boekel answered ·
Yes no problem, you don't need Hub or ESS assistants for that also.
You basically set the charging current to 0 A to prevent it from charging, and use an assistant (generator relay assistant is easiest) to (dis) connect the grid (ignore AC-in)
carlos-colasanti answered ·
Thank you a lot Boekel. I just have done your recomendation. I looking for the results. I will comment soon. Best regards
