I would like to control an external 220 volt ac relay with the build-in relay in the Phoenix smart IP43 charger, but the manual states the relais can switch 5 Amp to 28 Volts DC. The coil on the external 220 volt relay does only consume 40 mA / 220 volt. Is the internal relay able to handle this ?
