short question: where can I remove the sun icon from the PV-tile? I have access to my RaspberryPi by FTP. So I just need to now the file and the path...
Thank you.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Thank you.
Thank you! I've found it. Path is: /opt/victronenergy/themes/ccgx/images
@Itsme, I would like to change the name of the different boxes like you have, can you tell me how you did it. I can get into my cerbo with putty so if it's not a hard solution I think I might be able to do it. I'm mostly interested in changing the "PV Charger" to "Solar" as you did. I suspect you will have to walk me through it from step 1 to finish.
I updated GuiMods to make the icon less intrusive.
FYI:
One of the problems with this icon is it is drawn ON TOP of the text at full opacity. Other tiles with icons draw them in the parent object so they can be behind the text and made translucent.
The tile names are usually set in OverviewHubEnhanced.qml. Some like the Multi are set in their own file Multi.qml
The sun icon on the PV Charger tile is is originally in in the OverviewSolarChargerEnhanced.qml file, but moved it to OverviewHubEnhanced.qml
All these files are in /opt/victronenergy/gui/qml/
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
26 People are following this question.
