I am upgrading the 4 solar panel array on my sail boat and I'm backing into the size of the existing mounting rack. I have found a manufacturer with two models of 210W panels that fit. One model is 12v, the other is 24v. The panels will be wired to a MPPT 150/70 and feed a 880 AH battery bank of 4 220A Victron gel batteries. My question is which of these models will give the best charging profile? And what is the best configuration to wire them?
I have listed the panel specs below:
12v Panels:
Voltage MPP Vmp(V) - 16.77V
Current MPP Imp(A) - 12.48A
Open Circuit Voc(V) - 19.83
Short Circuit Current Isc(A) - 13.09A
24v Panels:
Voltage MPP Vmp(V) - 33.54V
Current MPP Imp(A) - 6.24A
Open Circuit Voc(V) - 39.66V
Short Circuit Current Isc(A) - 6.55A
The current set up is 4 120W panels wired as 2 x series, 2 x parallel. Everything works ok in this setup, I am just looking to increase my charging capabilities.
Thank you.
