marian-rada avatar image
marian-rada asked
Balance battery 2V x 24buc ??
Hello
I want to connect the 2V batteries in the attached diagram with Balance Battery.
Is the scheme possible?
Does it help balance 12v strings?
Thanks.balance-battery.jpgMarian
Battery Balancer
Egberth Bashweka avatar image
Egberth Bashweka answered ·
I didnt understand on balance meaning but here is a connection of 2V ,to make 12V systembat conenctn.png
netrange avatar image
netrange answered ·
... you combine 6x2V Cell´s to a single 12 Battery ... and this 4 times
... You need 3 Balancers for balancing a 48V System
https://www.victronenergy.de/upload/documents/Datasheet-Battery-Balancer-DE.pdf
kevgermany avatar image
kevgermany answered ·
As said, three balancers.
Each balancer has 3 connections. And balances 1 pair of 12V batteries (or strings as you're doing). Connection on balancer are to neg, mid point, positive. Victron have connection diagrams for 48V setups in the balancer focumentation which you can download. Just put your strings in place of the single cells they show.
