I would like to know if a 120/240 60hz generator can be used as the AC input (for charging) for my Quattro 48V/10K/230V/50Hz that is set to output 240V/60hz AC
If this is possible, how about some recommendations for a generator that will get along well with the Quattro. I wont need a large genny as our power requirements are fairly low, and this unit would be used only to charge the 225Ah Lithium battery bank during long dark weather.
Also this system is Off Grid. The only AC input will be the Generator. DC input is from our solar arrays.
