Looking to add blower fan to my 24V 3000. The blower is 12V. Should a 12V power be applied to the relay to have it act as a switch?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Yes, as long as the fan is pulling 4 amps or less (48W). If it is pulling more power, then "the relay" in the multiplus could be used to activate a bigger relay which act as the fan switch.
Edit: I assume you are talking about the primary relay (alarm relay)
It should be fine to use the primary relay.
You have to program your unit with VE Configure. Add two "programmable relay" assistants and configure them to activate the primary relay based on the fan. Here is a summary example:
28 People are following this question.
