Roger Parker avatar image
Roger Parker asked
Can Scripts be installed on a Cerbo GX?
Am I missing something or is it not possible to install these scripts on a Cerbo GX? I can't find a way to get a command line with the Cerbo. I love the extra information being displayed and would like to add it to my system 'but I don't see a way of doing it unless you're using a rasp Pi.
cerbo gxVenus OS
Kevin Windrem avatar image
Kevin Windrem answered ·
You should be able to ssh into Cerbo once you've set a root password. SSH on LAN must also be enabled.
There's no serial console on Cerbo if that is what you are looking for, and the command line interface can't be brought to the HDMI display.
